RJ11 Cable To Cut Down Interference
Have one of these https://www.amazon.co.uk/gp/product/B008IKVA1W/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 at the moment between my router and OR MK III master socket. I think I might be getting interference from the central heating causing drops and freezing on streaming. Just wondered if there was a better cable I might be able to use?
4 REPLIES 4
Fixes: 25
Re: RJ11 Cable To Cut Down Interference
These have a good reputation.
Do you actually need it to be 5 metres? Shorter is better.
With the coming of old age, you will know all the answers; but nobody will ask any of the questions any more
As I have said before I use two of these both 10m long with most of the wire bundled under my cabinet and I don't suffer from any form of degradation. However, with these being unavailable on Amazon I'm sure you'll get the shorter variant elsewhere online.
Thanks both.
I use one of these with an OR MK2 Socket and get :
Link Rate 79999 Kbps 19999 Kbps
If thats any help
