Quick reconnect batch script ?
ramissin
Can anyone help with a scripted method to disconnect and reconnect my hub1 router ?
Is it possible to do it via external batch file ?
These are my options, so far nothing I've tried works.
thx
bNNHArg
4 REPLIES 4
ramissin
Re: Quick reconnect batch script ?
Is there no way to get a new IP ? sometimes even switching the router on and off doesn't give me one.
bobpullen
Fixes: 288
Why do you want a new IP? You can probably do something with a Selenium script or similar on the local network but I'm not sure why you'd want to.
ramissin
Because downloads from certain file sites are restricted, meaning a 3 hour wait between downloads on one IP.
ipconfig/release ipconfig/renew has no effect so I'm looking for a similar method for the router.
Turning the router on and off sometimes works but it would be better to have a scripted method.
ramissin
Ok, from what I've managed to find out my IP is now "sticky". If I wanted a static IP I would have ordered one.
https://community.plus.net/t5/Fibre-Broadband/Changing-dynamic-IP-address/td-p/1332111
