Question about using TP-Link AC2800 modem router if I upgrade to fibre
FIXED- Subscribe to RSS Feed
- My Router
- Question about using TP-Link AC2800 modem router i...
10-07-2019 10:36 AM
Thinking of finally upgrading from ADSL2 to fibre and wondered if my existing modem router will work with Plusnet fibre connection?
As far as I can tell the router should be cable of both ADSL2 and VDSL (fibre). Can someone confirm if they have used this router with a fibre connection and if there are any issues. I assume I would just plug in as it is now and re-configure if required?
Any help / comments appreciated.
Fixed! Go to the fix.
Re: Question about using TP-Link AC2800 modem router if I upgrade to fibre
10-07-2019 11:06 AM
10-07-2019 11:10 AM
This topic has been moved from Fibre Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 100.0 (64-bit)
12-07-2019 6:45 AM
Thanks, that's what I thought also. Have taken the plunge and ordered the fibre upgrade and the Plusnet router as well just in case. Got a great deal so hopefully all will be fine.
Thanks,
- My Router
