Public Private Network issue
- My Router
- Public Private Network issue
09-05-2020 10:36 AM
Hi, since I started using the BTHub6, every time i start up a PC with Win 10, the networks ( 2.4 and 5 GHZ) have changed from Private to Public. This makes sharing stuff across the network and firewall permissions frustrating. I suspect the issue is more Windows than router but it is suspicious that it only started once i moved to the BT router.
Any ideas?
Message 1 of 2
(177 Views)
1 REPLY 1
Re: Public Private Network issue
09-05-2020 12:52 PM
It's definitely windows and you should be able to change it in your network settings.
Message 2 of 2
(158 Views)
- My Router
