Problem writing to portable drive on USB connection
- My Router
- Problem writing to portable drive on USB connectio...
12-07-2016 8:05 PM
I have connected a 500GB portable USB hard drive to my Hub One router. I can see it from windows file explorer and can read from it. However, I cannot write to it?
Can anyone help?
Thanks,
Ian
Message 1 of 2
(415 Views)
1 REPLY 1
Re: Problem writing to portable drive on USB connection
21-07-2016 1:26 PM
Hi ihmitchell,
Have you checked the power draw on the storage device as the maximum power draw on the port is 500mA, so the HDD/Storage device can't exceed this.
Message 2 of 2
(352 Views)
- My Router
