Problem with some equipment not connecting to the router
jb14
I am having problems with some connections.  My laptop and phone are connecting wirelessly but other machines, phones, tablets will not connect.  Do you have any suggestions?  I have tried restarting router restarting their equipment and disconnect/reconnect connection.
3 REPLIES 3
Mav
Fixes: 515
Re: Problem with some equipment not connecting to the router
Moderator's note(s):
Thread moved from Fibre Broadband to My Router.
Forum Moderator and Customer
Fixes: 1,600
Thanks for getting in touch @jb14
I'm sorry for the issues. I've made some changes to the wireless settings in your router which means you should see a new network name ending in 5GHz. If you find you have problems on the usual network name, I'd recommend going through the wireless troubleshooting steps explained Here.
If you have issues while on the 5GHz wireless frequency, it may be worth posting in this thread Here as we might be able to make changes to your router's firmware version.
jb14
Currently this has fixed my problem using either 5Ghz or standard line.  Standard line dropped out twice yesterday.
