Problem with broadcom network adapter
- My Router
- Problem with broadcom network adapter
16-10-2019 9:10 PM - edited 16-10-2019 9:12 PM
All devices in the home now connect fully to the WiFi yet the PC has this problem.
It states that there is a connection with internet access but as said above no webpages will load up after the initial 10 seconds.
When I connect an ethernet cable up, everything runs fine and fast so this is a wireless issue.
Could there be a problem with the network adapter in the PC? I'm unsure though as it finds and connects to the router with 4bar signal.
Re: Problem with broadcom network adapter
17-10-2019 12:51 PM
Try separating the 2.4 and 5 GHz bands on your router. See https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Try each in turn and use the best.
17-10-2019 12:56 PM
Moderators Note
This topic has been moved from Fibre to My Router
17-10-2019 2:02 PM
17-10-2019 2:33 PM
You could try updating the drivers on your PC. I use the free version of Driver Booster. You will be nagged to upgrade to the paid for version so I tend to remove it after use.
18-10-2019 4:31 PM
- My Router
