Printer connection
PeterARoach
Printer connection
Hi guys,
Just trying to connect my new printer to my home wifi and I"ve realise that i've lost the label on the route that has my passwords👎
What can I resolve this issue?
Cheers
Pete
3 REPLIES 3
Alex
Fixes: 13
Re: Printer connection
If you're using the PlusNet Hub One, I know it has a pull out card - I assume that is what you have lost?
I believe there is also a sticker on the router itself. I am not at my sisters at the moment (who uses our PlusNet connection), so I can't check.
daveplus
Fixes: 10
@PeterARoach
It is also on the bottom of the router
Fixes: 367
@PeterARoach
If your printer has WPS support then use that.
