Port Forwarding on the Sagemcon 2704N
- My Router
- Re: Port Forwarding on the Sagemcon 2704N
10-04-2015 10:51 AM
I go into advanced settings and port forwarding. I then choose add a new game or application. I then enter a name and choose no to not copy existing. I then add the port address 8080 in all fields and click apply. I then go to add game/application and select the name I have just added and select the sever I wish the port forwarded to. I then click add and it appears on the page. I then exit the router. Sometimes clicking http://<myipaddress>:8080 works but then after a while to fails and will not come back. Help please
10-04-2015 10:53 AM
10-04-2015 10:55 AM
10-04-2015 2:23 PM
You could test "http://<myipaddress>:8080" by using a free proxy server.
Not all free proxy servers work with port 8080 but this one does:
http://www.uk-proxy.co.uk
10-04-2015 4:22 PM
10-04-2015 4:28 PM
10-04-2015 4:37 PM
10-04-2015 5:57 PM
10-04-2015 6:18 PM
10-04-2015 7:31 PM
So then I created port forwarding to it and it worked!!!
I then went into the expert menu http://192.168.1.254/expert_user.html and under Advanced Setup and Lan I allocated a fixed IP address to the servers MAC address.
It works and I have a fixed IP address
Many thanks
24-09-2015 4:02 AM
02-10-2015 11:36 AM
Quote from: TardisRepairMan ejs - many many thanks - this led me to the answer. I had given the server a fixed IP address and it was listed as Unknown<mac address> So the first thing I did was change the server to use DHCP. It was then listed as <ServerName><mac address>
That's very promising, I have the same behaviour than you (Unknown<mac address>). What do you mean by "change the server to use DHCP?
02-10-2015 12:26 PM
02-10-2015 1:55 PM
Quote from: ejs you'll need to change it back to "obtain automatically".
Unfortunately I never changed the default behaviour for obtaining the Ip adress (via DHCP so). My server Os is wheezy running on a Raspberry Pi.
08-10-2015 11:23 AM
Turning off the DHCPv6 in expert view solved my problem.
I have now port forwarding working!
- My Router
