Port Forwarding not working correctly
Thomas5020
Trying to port forward a couple of games. My call of duty port forward is very intermittent, sometimes it works so i get open NAT sometimes it doesnt so i get moderate or strict. My Minecraft port forward is the biggest issue though. Nobody can connect to the server i'm running, but the server is confirmed working as I can join it. Any ideas?
7 REPLIES 7
bill888
Champion
Fixes: 36
Re: Port Forwarding not working correctly
Can you tell us which router you are using?
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Thomas5020
Couldn't give you  a model number or anything, but it's small, white and has plusnet written on the front. The LED's are green
bill888
Champion
Fixes: 36
Is it one of these two models?
https://community.plus.net/aptgm87544/attachments/aptgm87544/Fibre/12229/1/IMG_9621.JPG
2704n on the left.
TG582n on the right.
Thomas5020
Its the 2704n
bill888
Champion
Fixes: 36
I'm afraid if you google 'Plusnet 2704n port forwarding', you will soon discover this router has a history of issues.
I can only suggest you try this solution:
https://community.plus.net/t5/Fibre-Broadband/Sagemcom-2704n-port-forwarding/td-p/1217680
If all else fails, you may need to consider a different router.
What router did you use previously?
Thomas5020
BT HomeHub 3, since i switched to plusnet recently
bobpullen
Fixes: 289
Home Hub 3 will work with our service, you'll just need to reconfigure it to use your Plusnet login credentials.
