Port Forwarding Bug
- My Router
- Port Forwarding Bug
Port Forwarding Bug
29-10-2017 7:04 PM
Hi, I'm using a Hub One and I've discovred some kind of bug preventing me from forward any UDP ports. I constantly get this message:
The game or application you’ve selected conflicts with an application () you’ve already assigned to another device. Please remove the other application or select the same device. |
There are no other applications forwarded, I removed them all.
Does anyone know of a way around this?
Message 1 of 2
(894 Views)
1 REPLY 1
Re: Port Forwarding Bug
30-10-2017 12:02 PM
So I reset my router and now the port settings are added fine, however the ports themselves still do not register as being forwarded in my program.
Message 2 of 2
(836 Views)
