Port 44158 for Helium hotspot not working
Fixes: 1,662
Re: Port 44158 for Helium hotspot not working
Hi @Luke3
Excellent, thanks for the confirmation!
Let me know if there’s anything else you’d need help with
alexkbambridge
Hi @Gandalf
I am having the same issue on my side regarding this. Please would you be able to have a look on your side?
Thanks Alex
Fixes: 1,662
Hi @alexkbambridge
From what I can see the broadband firewall is turned off via your account already.
Can you try using port forwarding?
pphammer
I'm also having the same issue. I just changed to plusnet and so far i've not been able to workout what to do to get my helium box setup.
Zinsha
Hi Gandalf,
I'm having the issue here. Would you mind making some changes on your end so it works for me too please?
Pn6
Evening Gandalf,
Really struggling with this exact issue Luke was having.
Is there any chance you could please point me in the right direction to get it fixed.
Joined plusnet yesterday and I cannot figure it out
adamwalker
Fixes: 223
Hi @Pn6 I've just checked your account and I'm not seeing the same issue that Gandalf fixed for Luke3 so it would be best to try and set up port forwarding on your router.
 Adam Walker
Pn6
Hi Adam, I have just sent you a private message.
I have already set up a port forward on the router
adamwalker
Fixes: 223
Thanks for getting back to me, just to double check have you set the port forwarding rules up for both TCP and UDP?
 Adam Walker
bisto52
Hi Luke, I'm having the same problem as gandolf in this chat, I cant seem to get port 44158 to open. Could I get the same changes to my account as you did for gandolf ?
Fixes: 382
@bisto52 You have asked the wrong person to see if they can assist - only those identified as 'staff' on their avatars can do what you ask, although I would suggest you start your own topic, preferably with a little more detail.
