Plusnet's hub one router interface
Xabre
Hi all,
I've been struggling to find pictures of the new router interface and I'm wondering whether anyone could post pictures for me please.
Thank you in advance.
6 REPLIES 6
Mustrum
Fixes: 77
Re: Plusnet's hub one router interface
There are instructions in the Help Centre
Xabre
Unless I'm being really stupid I can't find anything in regards to the interface (the web browser where you access the router settings)
Mustrum
Fixes: 77
Maybe just looking hard enough try here or the video guides you through settings.
jaread83
Fixes: 81
Hi @Xabre, welcome to the Community.
The link @Mustrum provided was the router setup guide to help you get started when setting up. There is also a user guide which might help you further. Fou can find it here Router user guides.
There are no pictures of the interface here but it does show you how to log in and do certain actions in the interface like port forwarding, changing wifi password etc.
Hope this helps.
Xabre
Thanks both Smiley
markhawkin
Fixes: 12
Attached a few screen shots from the "top level" menus.
I've removed a few bits of personal info but you should get the idea,
It should suit the "average" user well.
Router screen 2.pngRouter screen 3.pngRouter screen 4.pngRouter screen 5.png
