Plusnet hub one connected to Network NAS
natedogg457
Sorry this is wrong place... How can i connect Nas to plus net hub 1 to view it remotely away from home as i am having trouble connecting it i have already got a static ip and it does not seem to be connecting me to the NAS how do i port forward it to my router?,
5 REPLIES 5
bill888
Champion
Fixes: 36
Re: Plusnet hub one connected to Network NAS
The Hub One is a rebadged BT Home Hub 5, you can find generic port forwarding instructions here
 http://bt.custhelp.com/app/answers/detail/a_id/8790/~/how-do-i-set-up-port-forwarding-on-my-bt-hub%3...
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
markhawkin
Fixes: 11
You probably can't. The Hub One doesn't have an inward VPN facility as far as I can see.
Some domestic NAS allow remote access via a service provided by the supplier (my WD supports this).
Mustrum
Fixes: 73
Which NAS do you have? This may help if its a Synology.
natedogg457
HP ProLiant Microserver.
markhawkin
Fixes: 11
I would expect a server such as the HP range to come without a server build and for the user to deploy their build of choice.
There won't be supplier support for external access.
The best bet might be to buy a replacement router that supports external VPN access. The Draytek 28xx range does but I'm sure others will suggest alternatives.
