Plusnet...Problems...Problems
ImInIT
After the issues with problems at the exchange, now we are experencing erratic speed.
Dropping from 30 Mbps to just 3 or 4.
What is going on with this supplier?
The most inconsistent provider I have used, and I have tried many.
Can someone sort this out.
Thanks.
Tags (2)
4 REPLIES 4
ImInIT
Re: Plusnet...Problems...Problems
CORRECTION...THE FIBRE IS OK
Its the Wifi...First time its happened...Apologies
Mav
Fixes: 507
Moderator's note:
Based on the previous post I have moved this from Fibre Broadband to My Router where more appropriate advice may be gained.
Forum Moderator and Customer
bill888
Champion
Fixes: 36
Try splitting the 2.4 and 5 ghz wifi on Hub One to see if it resolves your wifi speed issues.
https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/td-p/1351950
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
EmilyD
Fixes: 117
Hi @ImInIT, I'm sorry to hear that you're experiencing issues with your WiFi connection.
I would definitely recommend that you try @bill888's suggestion of splitting the wireless bands. Please let us know if the issue persists after you've done this.
 Emily D
