Plusnet Hub one router issue
FIXED- Subscribe to RSS Feed
- My Router
- Plusnet Hub one router issue
Re: Plusnet Hub one router issue
09-07-2017 4:24 PM
I've flagged this up internally for further investigation.
09-07-2017 4:49 PM
Moderator's note:
Your post prior to message #11 was released from the Spam Filter but as it was repeated in #11 I removed it
Forum Moderator and Customer
09-07-2017 5:07 PM
@Townman wrote:
A ping / trace route is not overly helpful - the servers might well be there and alive, but that does not mean that NTP traffic is passing on port 123.
Yeah I know but best to show as much detail as possible, as they can't reproduce the issue locally.
09-07-2017 6:27 PM
I'm seeing the same issue, my router is cycling through four IP addresses...
2000-01-01 00:01:39 SNTP Unable to contact server: 212.159.13.49
2000-01-01 00:07:24 SNTP Unable to contact server: 212.159.13.50
2000-01-01 00:13:10 SNTP Unable to contact server: 212.159.6.9
2000-01-01 00:18:55 SNTP Unable to contact server: 212.159.6.10
09-07-2017 7:50 PM
You completely miss the point - pings add zero value here. So "as much detail as possible" does not help in the context of the issue. I am sure that when the covers are taken off this, its going to be the back haul network or the gateway the individual users are connected to.
If you want to add value, give the A.B.C.0 part of your IP address and the gateway you connect into - see http://usertools.plus.net/@gateway/
09-07-2017 8:42 PM
In advance of the PN guys getting on to this, can people reporting this issue please identify the A.B.C.0 part of their IP addresses and the gateway they are connected to.
Posts showing successful pings and failed NTP connections or router screen shots do not convey any context which is going to help the tech guys profile those for whom this is failing distinctly from those of us for which it works.
NTP is not broken - it would though appear that for some the access to the NTP server (or the response there from) is somehow broken. The IP addresses being pinged are virtual IP addresses, behind which their are multiple DNS / NTP services in different data centres. Hence the need for a context to those having this issue.
09-07-2017 8:54 PM
I assume this is what you're asking for?
core2-hu0-18-0-0.southbank.ukcore.bt.net (62.172.103.24)
It does say it cannot identify my gateway.
09-07-2017 8:59 PM - edited 09-07-2017 9:05 PM
Yes - Thanks - Indeed it does not help that for some gateways, the gateway tool has some missing information. The PUG member who manages this tool (now also a SU) has been trying to obtain the additional data for a wee while.
What you have provided should mean enough though to those who will need to know,
09-07-2017 9:18 PM
the "Which gateway" tool for me says this ....
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Issues topic in the Community forums will help us to diagnose the problem.
core2-hu0-18-0-0.colindale.ukcore.bt.net (62.172.103.16) 7.054 ms
10-07-2017 10:39 AM
Morning all. Managed to replicate this, suspect it's only affecting those connecting via certain parts of our dedicated network, particularly those that see the hop after there router time out on an outbound traceroute (which itself isn't a problem, it just indicates that you're probably on the affected route):
~$ traceroute -I community.plus.net traceroute to community.plus.net (46.19.168.229), 30 hops max, 60 byte packets 1 dsldevice.lan (192.168.1.254) 13.040 ms 13.043 ms 13.040 ms 2 * * * 3 133.hiper04.sheff.dial.plus.net.uk (195.166.143.133) 16.997 ms 18.147 ms 18.718 ms 4 be3-3102.pcn-ir02.plus.net (195.166.143.132) 22.839 ms 26.047 ms 26.054 ms 5 195.99.125.140 (195.99.125.140) 26.051 ms 27.922 ms 27.930 ms 6 core3-hu0-14-0-7.faraday.ukcore.bt.net (195.99.127.64) 27.930 ms 13.297 ms 13.280 ms 7 peer2-et-9-3-0.faraday.ukcore.bt.net (62.6.201.195) 15.406 ms 15.402 ms 17.407 ms 8 * * * 9 216.52.199.38 (216.52.199.38) 19.714 ms 20.952 ms 20.302 ms 10 core1.be3.ams004.pnap.net (216.52.199.50) 23.756 ms 23.945 ms 21.467 ms 11 border3.ae1-bbnet1.ams004.pnap.net (95.172.78.38) 21.443 ms 19.641 ms 19.607 ms 12 lithiumtechinc-5.edge1.ams004.pnap.net (95.172.78.146) 20.135 ms 17.713 ms 18.019 ms 13 aptgm87544.lithium.com (46.19.168.229) 18.435 ms 18.755 ms 20.421 ms
We've an incident raised and our engineers are currently looking into it (ref: 100657)...
10-07-2017 11:39 AM - edited 10-07-2017 11:48 AM
Should be on the mend now folks
~$ ntpdate -d ntp.plus.net 10 Jul 11:36:00 ntpdate[7240]: ntpdate 4.2.8p4@1.3265-o Wed Jun 28 18:08:13 UTC 2017 (1) Looking for host ntp.plus.net and service ntp 212.159.13.50 reversed to cdns02.plus.net cdns02.plus.net forward check lookup fail: Name or service not known host found : 212.159.13.50 (cdns02.plus.net) transmit(212.159.13.50) receive(212.159.13.50) transmit(212.159.6.10) receive(212.159.6.10) transmit(212.159.13.49) receive(212.159.13.49) transmit(212.159.6.9) receive(212.159.6.9) transmit(212.159.13.50) receive(212.159.13.50) transmit(212.159.6.10) receive(212.159.6.10) transmit(212.159.13.49) receive(212.159.13.49) transmit(212.159.6.9) receive(212.159.6.9) transmit(212.159.13.50) receive(212.159.13.50) transmit(212.159.6.10) receive(212.159.6.10) transmit(212.159.13.49) receive(212.159.13.49) transmit(212.159.6.9) receive(212.159.6.9) transmit(212.159.13.50) receive(212.159.13.50) transmit(212.159.6.10) receive(212.159.6.10) transmit(212.159.13.49) receive(212.159.13.49) transmit(212.159.6.9) receive(212.159.6.9) server 212.159.13.50, port 123 stratum 2, precision -21, leap 00, trust 000 refid [212.159.13.50], delay 0.03423, dispersion 0.00008 transmitted 4, in filter 4 reference time: dd0dd304.977335a0 Mon, Jul 10 2017 11:18:44.591 originate timestamp: dd0dd717.60ab57a6 Mon, Jul 10 2017 11:36:07.377 transmit timestamp: dd0dd717.62c05556 Mon, Jul 10 2017 11:36:07.385 filter delay: 0.03522 0.03423 0.03430 0.03458 0.00000 0.00000 0.00000 0.00000 filter offset: -0.01251 -0.01278 -0.01273 -0.01263 0.000000 0.000000 0.000000 0.000000 delay 0.03423, dispersion 0.00008 offset -0.012786 server 212.159.6.10, port 123 stratum 2, precision -21, leap 00, trust 000 refid [212.159.6.10], delay 0.03383, dispersion 0.00055 transmitted 4, in filter 4 reference time: dd0dd355.eea58140 Mon, Jul 10 2017 11:20:05.932 originate timestamp: dd0dd717.93c2492f Mon, Jul 10 2017 11:36:07.577 transmit timestamp: dd0dd717.95f4b72e Mon, Jul 10 2017 11:36:07.585 filter delay: 0.03584 0.03383 0.04024 0.03392 0.00000 0.00000 0.00000 0.00000 filter offset: -0.01208 -0.01272 -0.00963 -0.01274 0.000000 0.000000 0.000000 0.000000 delay 0.03383, dispersion 0.00055 offset -0.012720 server 212.159.13.49, port 123 stratum 2, precision -21, leap 00, trust 000 refid [212.159.13.49], delay 0.03506, dispersion 0.00029 transmitted 4, in filter 4 reference time: dd0dd304.977335a0 Mon, Jul 10 2017 11:18:44.591 originate timestamp: dd0dd717.c6f0dc57 Mon, Jul 10 2017 11:36:07.777 transmit timestamp: dd0dd717.c927a7c2 Mon, Jul 10 2017 11:36:07.785 filter delay: 0.03630 0.03545 0.03571 0.03506 0.00000 0.00000 0.00000 0.00000 filter offset: -0.01279 -0.01309 -0.01314 -0.01340 0.000000 0.000000 0.000000 0.000000 delay 0.03506, dispersion 0.00029 offset -0.013400 server 212.159.6.9, port 123 stratum 2, precision -21, leap 00, trust 000 refid [212.159.6.9], delay 0.03413, dispersion 0.00029 transmitted 4, in filter 4 reference time: dd0dd355.eea58140 Mon, Jul 10 2017 11:20:05.932 originate timestamp: dd0dd717.fa4a12a2 Mon, Jul 10 2017 11:36:07.977 transmit timestamp: dd0dd717.fc5a7e9e Mon, Jul 10 2017 11:36:07.985 filter delay: 0.03526 0.03413 0.03526 0.03444 0.00000 0.00000 0.00000 0.00000 filter offset: -0.01260 -0.01277 -0.01221 -0.01249 0.000000 0.000000 0.000000 0.000000 delay 0.03413, dispersion 0.00029 offset -0.012777 10 Jul 11:36:07 ntpdate[7240]: adjust time server 212.159.6.10 offset -0.012720 sec
10-07-2017 11:42 AM - edited 10-07-2017 11:42 AM
Good job all round!
10-07-2017 11:47 AM
Mine finally connected at about 1035am.
Thanks.
10-07-2017 11:52 AM
10:33:28, 10 Jul. | (251197.660000) NTP synchronization success! |
10-07-2017 12:11 PM
All good for me too. Thanks for sorting it out.
- My Router
