Plusnet Hub one router issue
FIXED- Subscribe to RSS Feed
- My Router
- Re: Plusnet Hub one router issue
06-07-2017 7:25 PM
Hi All,
I have the Plusnet access control set in my router to block internet and night to stop the kids accessing the internet when they should be in bed. It seems that for some reason tonight that the access control has already kicked in and is blocking all of the kids devices.
The one thing that I have noticed is that the Current Time in the Setting says Retreiving and has done all evening. Could that be why its blocking the devices? I have tried restarting the router, refreshing it, unplugging but nothing seems to work.
Anyone got any ideas?
Thanks in advance
Fixed! Go to the fix.
07-07-2017 6:46 AM - edited 07-07-2017 6:49 AM
Possibly ntp.plus.net was down? This seems to tie-in https://community.plus.net/t5/Broadband/Plusnet-time-server-down/m-p/1455185
If still a problem are you able to set the time manually for now?
07-07-2017 3:45 PM
07-07-2017 8:52 PM
The time is still retreiving. I have no idea how to set it manually if I even can?
08-07-2017 12:59 PM - edited 08-07-2017 6:56 PM
Woke up today with exactly this issue (all timed events broken because the router is unable to confirm time) just says retrieving....
And no option to manually set it.
Have had to disable parental controls just to let people online.....
08-07-2017 6:30 PM
Yeah I have to, which is pointless.
Anyonw know if or how we can set the time manually or what we can do to fix?
09-07-2017 11:22 AM
Sorry to hear that.
Anyone tried turning the broadband firewall off or to low in their Member Centre to see if that fixes the issue?
09-07-2017 12:17 PM - edited 09-07-2017 12:21 PM
No it is already set to off. and still no time... ( even rebooted the router to check)
09-07-2017 1:33 PM - edited 09-07-2017 1:38 PM
I'm having the same issue. Current time says "Retrieving" so Access Control isn't working. It's been like it since Friday morning.
09-07-2017 1:50 PM
Can someone that's having this issue send us a screenshot of where this is showing as 'retrieving time' and we'll get this looked at.
09-07-2017 2:04 PM - edited 09-07-2017 2:53 PM
screen shot attached
From event log (from today 9-7-17 @14:50)
05:57:27, 23 Mar. (107861.690000) NTP synchronization failure! 05:48:17, 23 Mar. (107311.660000) NTP synchronization failure! 05:39:07, 23 Mar. (106761.630000) NTP synchronization failure! 05:29:57, 23 Mar. (106211.600000) NTP synchronization failure! 05:20:47, 23 Mar. (105661.570000) NTP synchronization failure! 05:11:37, 23 Mar. (105111.540000) NTP synchronization failure! 05:02:27, 23 Mar. (104561.510000) NTP synchronization failure! 04:53:17, 23 Mar. (104011.480000) NTP synchronization failure! 04:44:07, 23 Mar. (103461.440000) NTP synchronization failure! 04:34:57, 23 Mar. (102911.410000) NTP synchronization failure! 04:25:46, 23 Mar. (102361.380000) NTP synchronization failure! 04:16:36, 23 Mar. (101811.350000) NTP synchronization failure! 04:07:26, 23 Mar. (101261.310000) NTP synchronization failure! 03:58:16, 23 Mar. (100711.180000) NTP synchronization failure! 03:49:06, 23 Mar. (100161.150000) NTP synchronization failure! 03:39:56, 23 Mar. (99611.120000) NTP synchronization failure! 03:30:46, 23 Mar. (99061.080000) NTP synchronization failure! 03:21:36, 23 Mar. (98511.050000) NTP synchronization failure! 03:12:26, 23 Mar. (97961.020000) NTP synchronization failure! 03:03:16, 23 Mar. (97410.980000) NTP synchronization failure! 02:54:06, 23 Mar. (96860.950000) NTP synchronization failure! 02:44:56, 23 Mar. (96310.920000) NTP synchronization failure! 02:35:46, 23 Mar. (95760.890000) NTP synchronization failure! 02:26:36, 23 Mar. (95210.850000) NTP synchronization failure! 02:17:26, 23 Mar. (94660.810000) NTP synchronization failure! 02:08:16, 23 Mar. (94110.770000) NTP synchronization failure! 01:59:06, 23 Mar. (93560.740000) NTP synchronization failure! 01:49:56, 23 Mar. (93010.710000) NTP synchronization failure! 01:40:46, 23 Mar. (92460.680000) NTP synchronization failure!
09-07-2017 2:58 PM
We've just tested that page on one of the same routers and can't replicate the issue, is this the same error that the others in this thread are seeing too?
Our page looks like this:
09-07-2017 3:03 PM
>ping ntp.plus.net Pinging ntp.plus.net [212.159.6.10] with 32 bytes of data: Reply from 212.159.6.10: bytes=32 time=10ms TTL=60 Reply from 212.159.6.10: bytes=32 time=10ms TTL=60 Reply from 212.159.6.10: bytes=32 time=10ms TTL=60 Reply from 212.159.6.10: bytes=32 time=10ms TTL=60 Ping statistics for 212.159.6.10: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 10ms, Maximum = 10ms, Average = 10ms
tracert ntp.plus.net Tracing route to ntp.plus.net [212.159.6.10] over a maximum of 30 hops: 1 8 ms <1 ms <1 ms PNHUB1 [192.168.1.254] 2 * * * Request timed out. 3 * 10 ms 10 ms 141.hiper04.sheff.dial.plus.net.uk [195.166.143.141] 4 11 ms 11 ms 12 ms be3-3106.psb-ir02.plus.net [195.166.143.140] 5 10 ms 10 ms 10 ms cdns02.plus.net [212.159.6.10] Trace complete.
tracert 212.159.6.10 Tracing route to cdns02.plus.net [212.159.6.10] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms PNHUB1 [192.168.1.254] 2 * * * Request timed out. 3 * * * Request timed out. 4 10 ms 11 ms 11 ms be3-3106.psb-ir02.plus.net [195.166.143.140] 5 10 ms 10 ms 10 ms cdns02.plus.net [212.159.6.10]
09-07-2017 3:40 PM
A ping / trace route is not overly helpful - the servers might well be there and alive, but that does not mean that NTP traffic is passing on port 123.
09-07-2017 4:09 PM
21:59:59, 23 Mar. | (165612.550000) NTP synchronization failure! |
21:50:49, 23 Mar. | (165062.520000) NTP synchronization failure! |
21:41:39, 23 Mar. | (164512.490000) NTP synchronization failure! |
21:32:29, 23 Mar. | (163962.460000) NTP synchronization failure! |
- My Router
