Plusnet Hub one router issue
NYGiants1978
Hi All,
I have the Plusnet access control set in my router to block internet and night to stop the kids accessing the internet when they should be in bed.  It seems that for some reason tonight that the access control has already kicked in and is blocking all of the kids devices.
The one thing that I have noticed is that the Current Time in the Setting says Retreiving and has done all evening.  Could that be why its blocking the devices?  I have tried restarting the router, refreshing it, unplugging but nothing seems to work.
Anyone got any ideas?
Thanks in advance
32 REPLIES 32
southerner
Re: Plusnet Hub one router issue
Possibly ntp.plus.net was down? This seems to tie-in https://community.plus.net/t5/Broadband/Plusnet-time-server-down/m-p/1455185
If still a problem are you able to set the time manually for now?
Fixes: 1,600
I've checked with our network team and I can confirm that our NTP servers are working correctly.
NYGiants1978
The time is still retreiving.  I have no idea how to set it manually if I even can?
aramil
Woke up today with exactly this issue (all timed events broken because the router is unable to confirm time) just says retrieving....
And no option to manually set it.
Have had to disable parental controls just to let people online.....
NYGiants1978
Yeah I have to, which is pointless.
Anyonw know if or how we can set the time manually or what we can do to fix?
Fixes: 1,600
Sorry to hear that.
Anyone tried turning the broadband firewall off or to low in their Member Centre to see if that fixes the issue?
aramil
No it is already set to off. and still no time... ( even rebooted the router to check)
mrben
I'm having the same issue. Current time says "Retrieving" so Access Control isn't working. It's been like it since Friday morning.
Chris
Legend
Fixes: 169
Can someone that's having this issue send us a screenshot of where this is showing as 'retrieving time' and we'll get this looked at.
aramil
screen shot attached
8fKxzJh
From event log (from today 9-7-17 @14:50)
05:57:27, 23 Mar.
(107861.690000) NTP synchronization failure!
05:48:17, 23 Mar.
(107311.660000) NTP synchronization failure!
05:39:07, 23 Mar.
(106761.630000) NTP synchronization failure!
05:29:57, 23 Mar.
(106211.600000) NTP synchronization failure!
05:20:47, 23 Mar.
(105661.570000) NTP synchronization failure!
05:11:37, 23 Mar.
(105111.540000) NTP synchronization failure!
05:02:27, 23 Mar.
(104561.510000) NTP synchronization failure!
04:53:17, 23 Mar.
(104011.480000) NTP synchronization failure!
04:44:07, 23 Mar.
(103461.440000) NTP synchronization failure!
04:34:57, 23 Mar.
(102911.410000) NTP synchronization failure!
04:25:46, 23 Mar.
(102361.380000) NTP synchronization failure!
04:16:36, 23 Mar.
(101811.350000) NTP synchronization failure!
04:07:26, 23 Mar.
(101261.310000) NTP synchronization failure!
03:58:16, 23 Mar.
(100711.180000) NTP synchronization failure!
03:49:06, 23 Mar.
(100161.150000) NTP synchronization failure!
03:39:56, 23 Mar.
(99611.120000) NTP synchronization failure!
03:30:46, 23 Mar.
(99061.080000) NTP synchronization failure!
03:21:36, 23 Mar.
(98511.050000) NTP synchronization failure!
03:12:26, 23 Mar.
(97961.020000) NTP synchronization failure!
03:03:16, 23 Mar.
(97410.980000) NTP synchronization failure!
02:54:06, 23 Mar.
(96860.950000) NTP synchronization failure!
02:44:56, 23 Mar.
(96310.920000) NTP synchronization failure!
02:35:46, 23 Mar.
(95760.890000) NTP synchronization failure!
02:26:36, 23 Mar.
(95210.850000) NTP synchronization failure!
02:17:26, 23 Mar.
(94660.810000) NTP synchronization failure!
02:08:16, 23 Mar.
(94110.770000) NTP synchronization failure!
01:59:06, 23 Mar.
(93560.740000) NTP synchronization failure!
01:49:56, 23 Mar.
(93010.710000) NTP synchronization failure!
01:40:46, 23 Mar.
(92460.680000) NTP synchronization failure!
Chris
Legend
Fixes: 169
We've just tested that page on one of the same routers and can't replicate the issue, is this the same error that the others in this thread are seeing too?
Our page looks like this:
aramil
>ping ntp.plus.net
Pinging ntp.plus.net [212.159.6.10] with 32 bytes of data:
Reply from 212.159.6.10: bytes=32 time=10ms TTL=60
Ping statistics for 212.159.6.10:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 10ms, Maximum = 10ms, Average = 10ms
tracert ntp.plus.net
Tracing route to ntp.plus.net [212.159.6.10]
over a maximum of 30 hops:
  1     8 ms    <1 ms    <1 ms  PNHUB1 [192.168.1.254]
  2     *        *        *     Request timed out.
  3     *       10 ms    10 ms  141.hiper04.sheff.dial.plus.net.uk [195.166.143.141]
  4    11 ms    11 ms    12 ms  be3-3106.psb-ir02.plus.net [195.166.143.140]
  5    10 ms    10 ms    10 ms  cdns02.plus.net [212.159.6.10]
Trace complete.
tracert 212.159.6.10
Tracing route to cdns02.plus.net [212.159.6.10]
  1    <1 ms    <1 ms    <1 ms  PNHUB1 [192.168.1.254]
  3     *        *        *     Request timed out.
  4    10 ms    11 ms    11 ms  be3-3106.psb-ir02.plus.net [195.166.143.140]
Fixes: 160
A ping / trace route is not overly helpful - the servers might well be there and alive, but that does not mean that NTP traffic is passing on port 123.
mort7890
Fixes: 4
21:59:59, 23 Mar. (165612.550000) NTP synchronization failure!
21:50:49, 23 Mar. (165062.520000) NTP synchronization failure!
21:41:39, 23 Mar. (164512.490000) NTP synchronization failure!
21:32:29, 23 Mar. (163962.460000) NTP synchronization failure!
