Plusnet Hub default gateway - Why does this even work?
- My Router
- Re: Plusnet Hub default gateway - Why does this ev...
08-12-2019 6:16 PM
Hello,
I have just left Plusnet for TT after 11 months and decided to use the hub as another access point (wired and wireless)
I also have a BT HH6 online as an AP (as.254) so have set the +hub as .253, the thing is that there is not an option on the +hub to set the default gateway (which is now the TT router at .1) yet it seems to work although I've only tested wireless so far.
What trickery is going on here?
Re: Plusnet Hub default gateway - Why does this even work?
08-12-2019 6:31 PM - edited 08-12-2019 6:34 PM
Surely the hub, now AP is seen by the router as just another device connected to the router, the same as say a computer? So why would it need ta gateway to the outside world? Isn't that handled by the router?
08-12-2019 6:34 PM
I think you can't stop the Plusnet hub from allocating IP addresses via DHCP.
Ideally the only device with DHCP enabled should be the TT router.
I wouldn't expect it to work unless you acquired a devices IP address from the TT router.
08-12-2019 7:08 PM
Thanks for replying,
Yep the TT hub sees the +hub at .253 as expected but with the BT HH6 I am able to tell it where to find the gateway and thus DNS server so that it can direct locally connected traffic out into the WWW, the +hub does not have this option but still lets my phone connect to the internet as if it knows where to find the gateway and DNS.
It seems to auto detect the gateway as a DNS server, both the BT HH6 and +hub are working as I want but I can't understand why the +hub is working without the giving it what I thought would be the required information.
Cheers,
Gordon.
09-12-2019 7:35 AM
@Deedpopo I assume that you have dhcp disabled on both the hh5 and the hub one, since it probably wouldn't be working at all if it wasnt.
Any connected devices will get their default gateway via dhcp and therefore from the TT router which will supply its own address.
09-12-2019 10:14 AM
Yes, only the TT hub has DHCP enabled.
I was just pleasantly surprised that the +hub worked without an explicit setting to tell it the address of the gateway which the BT HH6 has.
Thanks,
Gordon.
09-12-2019 10:36 AM
Neither the hh5 or the +hub are acting as routers, they're just acting as network switches,. All devices have the tt router as the gateway and so any non local traffic will be directed at that.
09-12-2019 6:41 PM
Possibly this might help https://community.plus.net/t5/My-Router/Using-a-2nd-Plusnet-Hub1-as-a-Wireless-Access-point/td-p/138... I think I did similar myself recently using this info.
- My Router
