Plusnet Hub & TP Link Booster problems
- My Router
- Re: Plusnet Hub & TP Link Booster problems
05-10-2019 3:27 PM - edited 05-10-2019 3:27 PM
Hi all my Homehub 6 died last week so im back to using the Plusnet router.
I ended up buying a AC750 Wi-Fi Range Extender RE200.
Trouble is i cant connect to the 2.4ghz network on the extender when setting it up,it connects to the 5ghz fine any ideas ive change the 2.4ghz wifi channel but it still doesn't work also reset the booster twice.
The Tp links wifi is showing on my pc but its unable to connect when i click the 2.4ghz ssid ????
05-10-2019 3:57 PM
Just changed the Wireless interface type from up to 144 to 300 then reset up and fingers crossed its working
06-10-2019 3:46 PM
06-10-2019 4:08 PM
I've given up and have bought a tp link Archer VR400 just a shame the PlusNet router is so poor.
07-10-2019 10:50 AM
Sorry to hear this, @davebetts
Is the speed of your connection as you'd expect on a wired connection? Is it slow on wifi both via the extender and via a direct wifi connection?
Best wishes
Dave
- My Router
