Plusnet Hub Two with smart devices
Bleakers64
Dear all,
I am near the end of my basic unlimited broadband contract and have been tempted to upgrade to fibre by a good offer in a retention email.
Consequently, I’ve been posted a brand new Hub Two, sooper…. Plug it all in and away we go you would think?. I wish.
Phones, iPad, sky, hive, great.
However none of my Woox smart plugs or Wiz bulbs will reset and connect properly. These devices need an assigned 2.4 GHz channel, not a mixed broadcast channel, as confirmed by both helpdesks.
So, been into the admin section on the Hub Two and you can’t assign different names to the two channels. What.?Huh
Given I needed to get them working tonight, I’ve pulled the Hub Two for tonight and reconnected the Hub One.
I have read on other posts that it may be possible to switch off the 5GHz channel, set the plugs and bulbs up with the new SSID, then re-enable the 5GHz channel. Has anyone done this successfully? If not, what’s the plan?
I like the idea of faster speeds, but the faff this is causing is frustrating? Do other providers have a router that can have separate channels?
Very tempted to chuck the damn thing out of the window just now even if I’m reasonably competent…..
8 REPLIES 8
bobpullen
Fixes: 331
Re: Plusnet Hub Two with smart devices
My first suggestion would be to try temporarily disabling the 5GHz radio as you have mentioned.
Bleakers64
Thanks for the reply Bob, I guess I was hoping for something a bit more positive, someone has tried it and succeeded etc. Or frankly no it doesn’t work and I need a different router or sell all the smart plugs etc…
I’ll have a go tomorrow, but was hoping to have some idea of likely success…
bobpullen
Fixes: 331
Sorry, I've no personal experience with the smartplugs or bulbs you're using.
I do have a few 2.4GHz only devices on my network, including some smartplugs, but they seem to deal with the merged SSIDs without issue.
My smartbulbs operate via a wired bridge, so the hub SSIDs are nothing to do with their operation.
Fixes: 480
@Bleakers64
See this and the following post for another option. https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Separate-Bands-with-a-Smarthub-2-or-Pl...
If you want the same wireless performance as a Hub Two with the capability to split the bands then get an original BT Smarthub, sometimes called Smarthub 6, they are cheap on auction sites. Avoid the later Smarthub 2 as they, like the Hub Two, have locked synchronised bands. You will find setting instructions pinned at the top of this board.
Another suggestion would be buy a newer product such a router only and put the hub two in modem mode
Fixes: 586
There's a few threads on the BT forums that suggest that temporarily disabling the 5ghz band does work
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Smart-plugs-bulbs/td-p/2073356
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Reconnect-2-4GHz-smart-plug-to-5GHz-router-can-...
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Re-Smart-Plug-Connection/td-p/1897934
Fixes: 1,495
It worked with my central heating system.
Bleakers64
So, dear all, thank you for your comments.
The Woox plugs and Wiz light don’t operate via a bridge like the Hive, they connect to Wi-Fi directly. They both need a clean 2.4GHz channel for setup. So, as suggested, knock off the 5GHz channel, remove everything from the various apps, one at a time, reentering my Wi-Fi password each time for each item reconnected. What a drag.
However it seems to have worked, the plugs and lights are reconnected and with 5GHz turned back on they are responding properly…
Maybe need to be a bit more patient….🤔😳
