Plusnet Hub Two router settings
Plowman
Hello,
I have the Plusnet Hub Two router with Fibre 70 - 72Mb estimated download speed service.
I am having problems with my connection. It drops regularly.
If I factory reset my Hub Two router what are the standard router settings please?
What would I need to check or change please, following the reset?
Regards.
4 REPLIES 4
Fixes: 388
Re: Plusnet Hub Two router settings
@Plowman If you do a factory reset via the pinhole, the Hub will pick up the settings automatically - there is nothing you need to do manually.
However, if you are having regular drops, I suggest you follow this guide first - the chances are it is not fault with the Hub.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
Plowman
Hello John,
Thank you.
For information/reference purposes, is there a list off the Plusnet Hub Two router settings?
Thanks.
Regards.
Fixes: 388
Plowman
Hello John,
Thank you very much.
Regards.
