Plusnet Hub Two Wifi signal - general query
geoffers
Hi - looking at the signal strength on my Hub-2 for both 2.4gHz & 5gHz signals using Wifi Analyser (by Farproc - excellent app but sadly no longer available on Playstore 😟) I can see 2 signals per frequency. The overall signal stays constant for one of the displayed values (blue), but the other (pink) seems to come and go
This isn't causing me any connection problems, but I would be interested to know what's happening. Any experts out there got any thoughts?👍
For instance these images show the 2.4gHz signal -
  • the first shows 2 graphs Pink & Blue at roughly the same strength
  • the second shows the blue graph constant, but at that instant the pink one was "disappearing" from the display
  • the third shows the signals over time so you can see the signals are pretty much identical, but the pink drops out then returns briefly then drops again
11 REPLIES 11
Re: Plusnet Hub Two Wifi signal - general query
@geoffers
The Plusnet Hub Two is BT Smart Hub 2 in a white case, however the Hub two is missing a couple of features, Digital Voice and Wifi discs extender support.
The unnamed wifi signals are a leftover from the BT version to support the connections to the wifi extenders, it is not possible to disable the redundant signals
As you have found nothing to worry about
outcast
Aspiring Champion
Fixes: 19
I'm 'missing' something here ?
@geoffers
What SSID are you using to connect to your WiFi  - "PlusNet1" or "VMCJ"  ?
If it's "VMCJ", then it's good that it's on an unused channel, but why is it more than 30dBm lower power than "PlusNet1" at the same distance ?.  Just looking at the power levels I'd assume that "VMCJ" belongs to a neighbour, or other distant hotspot ?
If you're using "PlusNet1", what happens if you change wireless channel to "1", does the other "Plusnet1" stay on channel "6" ?.
Having each of the "Plusnet1" SSIDs on different wireless channels, would be better than sharing the same (if that's possible)
@outcast
Yes you are missing something, maybe no Hub Two knowledge?
outcast
Aspiring Champion
Fixes: 19
... which is why I asked the question, so that I can learn.
Just jesting 🙂
My thinking is the VMCJ network was not in the same property so I ignored it seeing the question is about the varying signal strength for the noname wireless signal.
@geoffers
The Hub two also has the same redundant signal for the 5GHz signal
outcast
Aspiring Champion
Fixes: 19
I know you were ! 😉
Additional question  (from the uninformed) !
If the pink signal is noname, then what is the red "Plusnet1" (if it isn't pink) in the bottom picture ?
Is the bottom picture showing signal strength for both 2.4GHz and 5GHz bands at the same time ? - which I doubt as I've just opened my up to date "WiFi Analyzer" app, and the signal strength graph only shows one band at a time.
Not used that app, but with Wifi Analyser author Kevin Yuan I'm sort of thinking it's displaying both 2.4 and 5 Ghz signals when looking at Signal Strengths time line graph
geoffers
Just to answer the various qn's
Yes it's Plusnet1 (I renamed the default SSID as I had other APs in the house as well) - neighbour is the VMCZ
The dual signals per freq stay with the assigned channel
Same is happening on the 5gHz
The red plusnet1 in the bottom pic refers to the 5gHz AP & the light blue is the 2.4gHz (the pink seems to piggyback with the blue)
BTW: It's not causing me any problems, but I'm just interested to know what I'm seeing
Thanks for your interest 👍
@geoffers
Hopefully I have answered your question, it is not unusual for the backhaul wireless signal used for wifi extenders to share the same channel, keeps the price down.
geoffers
>>>>>Not used that app, but with Wifi Analyser author Kevin Yuan I'm sort of thinking it's displaying both 2.4 and 5 Ghz signals when looking at Signal Strengths time line graph<<<<<
Looks like that's the one and same app - Found this on his website .....get a list of Wi-Fi analyzer apps. Wi-Fi Analyzer, developed by Kevin Yuan of farproc
....etc
outcast
Aspiring Champion
Fixes: 19
This is the "WiFi Analyser" I've got installed on an Android phone.
