Plusnet Hub One
Alex2x
Plusnet Hub One
Why is this router so dam noisey, I have put up with now for so long it works but geez it's horrible. Are they all like this or is mine just [-Censored-]
3 REPLIES 3
Strat
Fixes: 565
Re: Plusnet Hub One
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
Fixes: 390
Re: Plusnet Hub One
@Alex2x
It’s a well known ‘feature’ of these devices. Plusnet claim that the noise is acceptable and meets standards that they do not specify.
Apparently it’s better if you switch off the 5GHz band.
Alternatively give up with it and get a BT Smarthub 6 for little money from the likes of EBay.
Alex2x
Re: Plusnet Hub One
Sounds like a plan m8 thanks for that, I'm sick of listening to the dam thing.
Cheers m8.
