Plusnet Hub One
- My Router
- Plusnet Hub One
Plusnet Hub One
04-06-2018 11:06 PM
can the hub one router be used as a vpn?
Re: Plusnet Hub One
05-06-2018 12:59 AM
No
Re: Plusnet Hub One
05-06-2018 7:18 AM
LOL
thanks for the confirmation
i have another router but that went haywire when i connected it up
now im stuck with this router?
Re: Plusnet Hub One
05-06-2018 4:22 PM
No you can always buy a VPN compatible one. Plusnet are quite relaxed about you using your own. Setting data will be found here https://www.plus.net/help/broadband/broadband-connection-settings/
Re: Plusnet Hub One
05-06-2018 4:26 PM
