Plusnet Hub One
- My Router
- Re: Plusnet Hub One
Plusnet Hub One
16-04-2020 10:03 PM
Why is this router so dam noisey, I have put up with now for so long it works but geez it's horrible. Are they all like this or is mine just [-Censored-]
Message 1 of 4
(770 Views)
3 REPLIES 3
Re: Plusnet Hub One
16-04-2020 10:10 PM
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
Message 2 of 4
(764 Views)
Re: Plusnet Hub One
17-04-2020 1:05 PM
It’s a well known ‘feature’ of these devices. Plusnet claim that the noise is acceptable and meets standards that they do not specify.
Apparently it’s better if you switch off the 5GHz band.
Alternatively give up with it and get a BT Smarthub 6 for little money from the likes of EBay.
Re: Plusnet Hub One
17-04-2020 8:43 PM
Sounds like a plan m8 thanks for that, I'm sick of listening to the dam thing.
Cheers m8.
Cheers m8.
Message 4 of 4
(633 Views)
