Plusnet Hub One
computecsupport
Plusnet Hub One
can the hub one router be used as a vpn?
4 REPLIES 4
Browni
Aspiring Hero
Fixes: 60
Re: Plusnet Hub One
computecsupport
Re: Plusnet Hub One
LOL
thanks for the confirmation
i have another router but that went haywire when i connected it up
now im stuck with this router?Huh
Angry
Fixes: 418
Re: Plusnet Hub One
No you can always buy a VPN compatible one. Plusnet are quite relaxed about you using your own. Setting data will be found here https://www.plus.net/help/broadband/broadband-connection-settings/
computecsupport
Re: Plusnet Hub One
Ok thanks
