Plusnet Hub One won't store my plusnet password!
- My Router
- Plusnet Hub One won't store my plusnet password!
10-06-2016 3:06 AM - edited 10-06-2016 3:22 AM
My Plusnet Hub One router will store my custom admin password and my plusnet username, but it won't store my plusnet password!
This means every time my router requests a new IP (every day) it fails to reconnect until I...
web browse 192.168.1.254
log in as admin,
select settings,
select enter your broadband username and password.
re-enter my password
and click connect.
... It's soooo annoying that the internet is down for everyone in my house until I do this!
P.S. My password is 14 characters long and contains no special characters or spaces.
P.P.S. I had problems on the initial setup with the Plusnet login server not responding and timing out.
Re: Plusnet Hub One won't store my plusnet password!
23-07-2016 3:50 PM
I thought that the "your" hub one was registered to your account and would connect automatically (the network recognises the account that hub one should use).
Have you tried a complete reset then applying whatever settings changes you want but letting the account log in sort itself out ?
This won't work if you didn't get the Hub One directly from Plusnet for this account.
- My Router
