Plusnet Hub One vs Asus N56u
zishan
Is it worth replacing my Asus N56u with newly supplied PlusNet Hub One?
Thanks in advance
3 REPLIES 3
Anotherone
Champion
Fixes: 21
Re: Plusnet Hub One vs Asus N56u
See the PM I sent you in connection with your previous thread.
zishan
Would love to know if anyone has got faster speeds due to no bt modem being used with home hub?
Anotherone
Champion
Fixes: 21
I very much doubt it - if you are talking about Huawei modem vs BT HH5B; or an ECI modem vs BT HH5A or Plusnet Hub One. HH4's and earlier are not directly compatible with FTTC and so need to be used with a modem.
You can also use an HH5 / Hub One connected to a modem, using the WAN port on the HH/Hub One. That is something you can try without upsetting your connection to the Cab, but it will depend on your own network setup as to whether the HH/Hub One can be configured to what you need.
