Plusnet Hub One vs Asus N56u
FIXED- Subscribe to RSS Feed
- My Router
- Re: Plusnet Hub One vs Asus N56u
16-06-2016 4:24 PM
Is it worth replacing my Asus N56u with newly supplied PlusNet Hub One?
Thanks in advance
Fixed! Go to the fix.
19-06-2016 1:07 AM
See the PM I sent you in connection with your previous thread.
20-06-2016 11:06 PM
Would love to know if anyone has got faster speeds due to no bt modem being used with home hub?
21-06-2016 1:21 AM
I very much doubt it - if you are talking about Huawei modem vs BT HH5B; or an ECI modem vs BT HH5A or Plusnet Hub One. HH4's and earlier are not directly compatible with FTTC and so need to be used with a modem.
You can also use an HH5 / Hub One connected to a modem, using the WAN port on the HH/Hub One. That is something you can try without upsetting your connection to the Cab, but it will depend on your own network setup as to whether the HH/Hub One can be configured to what you need.
- My Router
