Plusnet Hub One router
- My Router
- Plusnet Hub One router
28-04-2020 6:59 PM
I'm an existing customer using unlimited broadband, due to be switched over to high speed fibre on Friday. Just received the new Plusnet Hub One router, Can I install it now to replace the 2704n router even though not switched over yet?
Re: Plusnet Hub One router
28-04-2020 7:02 PM
This topic has been moved from Fibre Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
28-04-2020 7:36 PM
Sorry i don't understand your reply, doesn't answer my question.
28-04-2020 7:45 PM - edited 28-04-2020 7:45 PM
@robmore It wasn't a reply as such, just a moderator moving it to a more appropriate board for better visibility
Yes, you can replace the router now. The hub one will work on both adsl and fibre. When your changeover happens, the router will automatically detect it and reconnect
28-04-2020 8:09 PM
Thanks very much for the clarification. I'll give it a go.
