Plusnet Hub One bridge mode to Asus RT-AC87U?
jackyaz
Does the Hub One support bridge mode for the Asus or am I better off buying something like a Draytek 130?
5 REPLIES 5
Browni
Aspiring Hero
Fixes: 60
Re: Plusnet Hub One bridge mode to Asus RT-AC87U?
The Hub One doesn't support bridge mode unfortunately.
jackyaz
Ah Ok cheers. Is the DrayTek 130 a good shout or not worth spending the money on vs. an OR modem? Believe my local cabinet is Huawei based.
Fixes: 415
Get a Huawei HG612 version 3B off Ebay. They're as cheap as chips, can be unlocked if you want to look at your WAN performance and work well.
jackyaz
Thanks, ordered one for £15 to dabble with unlocking
jackyaz
Got one and flashed the unlocked firmware. Am I right in that I change 0 settings on the OR Modem? I spotted things like QoS etc. as enabled but presumably these will be bypassed anyway? WAN page looks like this:
