Plusnet Hub One and firmware updates
- My Router
- Plusnet Hub One and firmware updates
02-02-2018 11:11 AM
Our Plusnet router has not had a firmware update in months - this concerns me because of the recent KRACK vulnerability.
Our firmware reads: Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 04/08/17
I've tried resetting the router via the pin hole on the back and waiting overnight as others have suggested but nothing changes - could anyone offer some advice here?
Re: Plusnet Hub One and firmware updates
02-02-2018 11:35 AM
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
02-02-2018 4:31 PM
I believe you have the latest firmware version. My understanding is KRACK would only affect the Hub One if it was acting in client mode to another wireless router. So if you aren't using two wireless routers in your setup, I think you don't need to worry about firmware fixes.
- My Router
