Plusnet Hub One and BT Smart Hub 2
- My Router
- Plusnet Hub One and BT Smart Hub 2
08-05-2020 8:15 PM
Hi
I have a Plusnet Hub One fibre router. Working from home and been experiencing poor quality voice over ip (voip). BT have tested the line and said the link is OK). We are currently using a neighbours wifi which is some 50ft away and works well. They are with BT and have a Smart Hub 2 router.
My question is will a BT Smart Hub 2 work on Plusnet?
Thanks.
Message 1 of 3
(1,027 Views)
2 REPLIES 2
Re: Plusnet Hub One and BT Smart Hub 2
08-05-2020 8:58 PM
Moderators Note
This topic has been moved from Fibre My Router
Message 2 of 3
(1,013 Views)
08-05-2020 8:59 PM
Yes is the short answer - though the app might not work
Message 3 of 3
(1,012 Views)
- My Router
