Plusnet Hub One. WiFi suddenly dropping to under 1mbps
FIXED- Subscribe to RSS Feed
- My Router
- Plusnet Hub One. WiFi suddenly dropping to under ...
30-08-2021 10:41 AM
Has it had it?
I remember having exactly the same issue years ago on the BT hub (which is practically identical). Replacing that hub resolved the issue.
Fixed! Go to the fix.
Re: Plusnet Hub One. WiFi suddenly dropping to under 1mbps
30-08-2021 12:37 PM
This topic has been moved from Fibre Broadband to My Router.
30-08-2021 1:43 PM
PN's Hub One router is famously poor at wifi performance.
If you use forum's search box, you'll get other wifi suggestions.
30-08-2021 2:13 PM
30-08-2021 6:25 PM
Your old HH5 was given a new frock as the Hub One. Many of us are very happy with the HH6 at £5-£20 on auction sites. Plenty of info on setting it up from stickies at start of this thread.
31-08-2021 8:20 AM
Good morning @withnail73
Thanks a lot for reaching out. Did authenticating your router solve this for you? Tests on the line this morning aren't finding any faults, the line is syncing at 40Mbps on my end.
31-08-2021 9:57 AM
16-09-2021 8:01 AM
16-09-2021 10:37 AM
Glad you are up and running. Well done and thanks indeed to Baldrick, he must have spent hours sorting the HH6 for PN.
16-09-2021 2:48 PM
Hiya @withnail73, glad to hear things are working well. Should you experience any further issues, just let us know.
- My Router
