Plusnet Hub One Router - Port Forwarding
GaryWilliams
I have a Plusnet Hub One router.  So I can access my office webcam from outside the office, I need to setup port forwarding.  To do this, I need to be able to specify the webcams' IP address and assign it to port 1025.  With the simplistic facilities available in the Hub One Router, how can I do this?
Cheers
Gary
2 REPLIES 2
Fixes: 1,482
Re: Plusnet Hub One Router - Port Forwarding
yeah
advanced settings > home network > devices
click your camera from devices and at the bottom you see 'always use this ip'
Once you've done that you can set port forwarding under:
firewall > port forwarding
you'll need to set up a new range under 'manage games and applications'
GaryWilliams
The webcam works perfectly (locally) on http://192.168.1.178.  The connection is wireless but does not show up under "Home Network - Devices - Wireless Connections" however often I hit "Refresh".  It is not listed in the DCHP Table.  I have setup a new application (Web Cam) on 192.168.1.178, port 80 but this does not solve the problem.
