Plusnet Hub One Replacement
superuser
Is it possible to get a Hub One to replace my cruddy 2704N
5 REPLIES 5
bill888
Champion
Fixes: 36
Re: Plusnet Hub One Replacement
I think Plusnet normally charge £99. Otherwise look at this thread if you are out of contract:
https://community.plus.net/t5/My-Router/Upgrade-from-TG582n-to-Hub-One/td-p/1349200
The Hub One is a rebadged Home Hub 5 type 'A'.  The HH5 type A, type B, and Hub One can be found on eBay too.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
BenB
Fixes: 20
Hi superuser,
You can purchase a Plusnet Hub One for £99 as @bill888 pointed out in there reply. From checking your account your not due for a re contract until early next year to be eligible for a replacement but can I ask what issue you are having with your current router?
superuser
It works. It's just poor wireless range and very week it need a reboot, it just seems to crud up. After a reboot it's OK.
It has physical limitations for my more tech use.
It really wouldn't have been too much to ask either for the ability to have multiple SSID's
Ah well
It looks like I'm just about to have to decide to stay or go according to the latest email from PN
Thanks for your interest
iancarr2016
if you someone with BT broadband get them to order a new smart hub (hub 6) it has even greater WIFI range than any other on market, £129 and as plusnet say BT routers will work
superuser
As it happens
A friend passed on to me his Billion 8800NL
So now I don't need the openreach modem
It lead me to a bit of a re-think and now it all seems good
