Plusnet Hub One Replacement
FIXED- Subscribe to RSS Feed
- My Router
- Plusnet Hub One Replacement
10-07-2016 11:03 AM
Hi all
I recently upgraded to Plusnet fibre but am not entirely happy with the supplied Plusnet one router. I find it quite restrictive in some of its settings.
Can anyone please suggest a reliable alternative router with good range/coverage?
Fixed! Go to the fix.
10-07-2016 11:07 AM
Have a read here http://forum.kitz.co.uk/index.php/topic,14436.0.html
Re: Plusnet Hub One Replacement
10-07-2016 11:19 AM - edited 10-07-2016 11:21 AM
Thanks rongtw for your speedy reply.
When sourcing a replacement for the Plusnet Hub one using fibre what should I be looking for in a potential replacement? Should it say FTTC, ADSL2/2+, ADSL, VDSL2?
When I purchased my router on my previous ADSL connection it was a bit more straight forward on knowing what to buy.
10-07-2016 1:37 PM
A VDSL is what you need,i was using BT Home Hub 5 & it works great.
10-07-2016 4:57 PM
Thank you both. You've been a great help!
