Plusnet Hub One Firmware Update
- My Router
- Plusnet Hub One Firmware Update
19-12-2018 3:23 AM
currently on Software version 4.7.5.1.83.8.226 Last updated 04/11/16 and was wondering if my 2 routers could be updated. both have been factory reset
Message 1 of 2
(478 Views)
1 REPLY 1
Re: Plusnet Hub One Firmware Update
19-12-2018 10:37 AM
Hi there.
As they're on really old firmware it's likely that the routers aren't on the hardware management(TR069) platform. If you can PM me the serial numbers and account usernames I'll be happy to sort that out.
Once they're on the TR069 platform, you'll just need to do another factory reset and they'll update within a day or so.
Message 2 of 2
(443 Views)
- My Router
