Plusnet Hub One - Configuration Question
firstalpha
I have just installed the Plusnet Hub One, having been using the Plusnet 582n router for several years...
How would I configure the Hub One to allow the ThinkBroadband Quality Monitor to work?
The Router configuration guide indicates that the BT Home Hub is not supported. Does this mean that Plusnet Hub One is also unable to use this useful service from ThinkBroadband?
Is there a similar service which will work with the Plusnet Hub One?
9 REPLIES 9
30FTTC06
Fixes: 4
Re: Plusnet Hub One - Configuration Question
If you have a ps3/etc.... then put that in the DMZ.
Oldjim
Fixes: 63
The Plusnet router won't respond to pings and you can't make it - so it won't work
30FTTC06
Fixes: 4
eh!
firstalpha
Thank you for this... I imagine this isn't the only downside to using the Plusnet router... 2 years ago, I had a lot of trouble with my plusnet service and this forum was a big help in my getting a half way reasonable download speed...
The village has just had an OpenReach fibre box installed and my Unlimited Fibre upgrade went live on Friday... I'm just hoping my line from the box will be up to standard...
The BT Wholesale Broadband Performance Test reveals that the service has NOT worked 'out of the box'... although, connecting to speedtest@speedtest_domain shows there is some connectivity...
RealAleMadrid
Aspiring Hero
Fixes: 55
Looks like your PlusNet profile has not been updated to fibre speed, you need to contact support to get it updated.
firstalpha
Thank you... I suspected as much... I sent a screen shot of the relevant webpage to support this morning...
Browni
Aspiring Hero
Fixes: 60
You should remove that screenshot as it contains your home phone number.
markhawkin
Fixes: 11
@firstalpha
I had a similar problem when my fibre went live.
For some curious reason, a factory reset on the Hub One seemed to fix it.
Assuming you don't have any "special" settings I suggest you give this a go .
firstalpha
@markhawkin wrote:
@firstalpha
Thank you for the suggestion, Mark... however, this didn't work for me...
The most impressive part of the upgrade is the improved latency... now 13/14ms compared to 30/40ms previously...
I did receive an email from Plusnet Support on Friday to say that my upload speed had been upgraded...
I'm pleased to be able to say, earlier today, a Plusnet CSC Analyst discovered a setting was incorrect within the line profiling system. Having found this, he adjusted the setting and my service was soon operating at an acceptable speed, as the appended test results show...
Thank you Plusnet and customer support...
