Plusnet Hub 2 for ThinkBroadband BQM
goldenlady46
Fixes: 5
@bobpullen Does Plusnet Hub Two work with thinkbroadband BQM as mine went all RED. Do you know to setup on my new Plusnet Hub Two Router?
5 REPLIES 5
Fixes: 585
Re: Plusnet Hub 2 for ThinkBroadband BQM
You need to enable ping in the Firewall configuration
goldenlady46
Fixes: 5
how to do it?
step by step instruction please
bobpullen
Fixes: 331
Log into the Hub Manager at http://192.168.1.254, navigate to Advanced > Firewall > Configuration. There's a toggle in there for allowing ICMP/Ping. Enable it and save the changes.
goldenlady46
Fixes: 5
@bobpullen many thanks it now working.
goldenlady46
Fixes: 5
BQM working now thanks @bobpullen
BQMBQM
