Plusnet Hub 2 does not work with security cameras requiring dual band
- My Router
- Plusnet Hub 2 does not work with security cameras ...
21-09-2022 9:33 PM
I have a Plusnet Hub 2 however I can no longer connect my security cameras as I can't split the signal 2.4ghz / 5ghz. Can any one help please?
Message 1 of 3
(1,368 Views)
2 REPLIES 2
Re: Plusnet Hub 2 does not work with security cameras requiring dual band
21-09-2022 9:52 PM
Moderators Note
This topic has been moved from Broadband to My Router
Message 2 of 3
(1,361 Views)
21-09-2022 9:55 PM
You can turn the 5Ghz band off for a short time, connect your devices and turn the 5Ghz back on again.
Once they're connected to the network once that should be enough.
Message 3 of 3
(1,359 Views)
- My Router
