Plusnet Hub 2 backup
pseudonoise
Does anyone know if creating a backup config file saves ALL of the router configuration ?  I want to try out the Hub 2 as a modem to test a OPNSense router but I would like to have a fallback to use the Hub2 as a router in case I hit issues.
I don't want to have to recreate my somewhat complex configuration from scratch !
Many thanks.
1 REPLY 1
Re: Plusnet Hub 2 backup
You need to navigate from the Home to >Advanced settings >System
As far as I am aware it saves everything as it has worked for me in the past.
I would still take screen shots as a precaution, it is also possible the export the DHCP IP Address allocation.
>Advanced settings >My Network
HTH
