Plusnet Hub 1 Port Forwarding...
IceColdRum
I am struggling to understand why this isn't working... I have forwarded port 8112 for the Deluge webui on my NAS in the living room which works wonderfully (and shows as open using http://canyouseeme.org/) yet I cannot get port 58846 open for the Deluge Daemon... I had it working about a week ago but now it just won't forward the port!
Can anyone offer some wisdom? or a hammer...
I've also found even if I disable the routers firewall entirely (purley for testing!) it still won't show the port as open
1 REPLY
IceColdRum
Re: Plusnet Hub 1 Port Forwarding...
As usual it was a simple fix...
I forgot to check that the daemon was actually running! Crazy3
