Plusnet HUB - Modem only mode?
darrencook
Is there any way to turn the router mode off and have modem only? as i have a asus router i want to use..
my issue is if i leave Dynamic Host Configuration Protocol enabled on the plusnet hub features on my asus will not work and that sucks...
Any info would be greatful...
1 REPLY 1
Fixes: 1,485
Re: Plusnet HUB - Modem only mode?
you can't have the hub one as a modem only.
you can pick up vdsl modems on fleabay reasonably priced.
