Plusnet Fibre Only - Modem Required?
ctrlz
I've just switched from Unlimited Fibre to "Fibre Only" (note:  not "Full Fibre", so not FTTP).
Current router setup is an old HG612 modem with an Eero router connected.
The question is: do I still need the HG612 or can I now plug directly into the Eero like you can with full fibre?
I'm a bit unclear on what the switch has actually entailed.  There definitely wasn't any work done inside the property; as far as I can tell, I'm just not paying for the phone line any more!
3 REPLIES 3
Fixes: 388
Re: Plusnet Fibre Only - Modem Required?
@ctrlz You leave your setup exactly as is - the only difference is that you lose the voice (phone) element, everything else stays exactly the same.
Fixes: 118
@ctrlz
What Euro router are you using?
Is it a modem / router? You still need a modem for a SOGEA (internet only) line. SOGEA is what you've been transferred to.
Fixes: 585
@bmc the Eero is just a router.
As @jab1 says, the setup stays exactly as it was before , using the HG612 modem
