Plusnet Access Control
- My Router
- Plusnet Access Control
16-09-2016 7:47 AM
I have the Plusnet Hub 1 router and generally use Access control with no problem.
Is there any way I can set internet access per day rather than have to go in each time I want to change the access allowance for that day? i.e. If I want internet blocked Sunday - Friday 10pm-7.30am but Friday & Saturday I want it Midnight to 7.30am am I able to set it for both options? Currently I have to change it on a Friday and then again on a Sunday.
Any ideas?
Re: Plusnet Access Control
10-10-2016 3:25 PM
Hi @NYGiants1978,
Thank you for getting in touch with us regarding the Access Control on your Plusnet Hub One router.
Unfortunately you would have to keep changing the times if you are wanting them separate on different days. The only thing that you could try is to set the device up again in the Access Control panel and leave the original selection as it is and then change the day and times on the other selection.
