PlusNet hub 2 hidden channels
ScottyKernow
Hi all
Just a bit of paranoia here, my hub 2 is broadcasting 2 hidden ssd's ( I'm assuming its the hub )
Is this normal?
Any help or advice would be gratefully received
11 REPLIES 11
iannewson
Fixes: 5
Re: PlusNet hub 2 hidden channels
ScottyKernow
Thanks for that
Did a search but didn't find it
@ScottyKernow
The Plusnet Hub Two is a rebadged BT Smart Hub 2 with modified firmware. The hidden channels are for features offered by the BT device which are not offered by Plusnet.
They should not impact the operation of your wireless network, I myself have not noticed any degradation.
Wireless can be turned off completely using the option in Advanced Wireless setting or when the Hub is in bridge mode (modem only)
HTH
ScottyKernow
Years ago BT used to allow other bt customers access to the Internet over your connection
Very few customers knew about this, certainly bt wasn't transparent about it
This sounds like the remnants of the sharing system
Browni
Aspiring Hero
Fixes: 61
@ScottyKernow they still do and it's not restricted to BT customers.
BT WiFi
Fixes: 480
See https://community.plus.net/t5/My-Router/Hub-Two-wireless-switched-off-but-still-has-unnamed-2-4GHz-a...
iannewson
Fixes: 5
@Baldrick1 Is there an echo 😉 ⬆️
ScottyKernow
Haha
BT are selling access to the customers wifi (which the customer pays for)
Wonder how much of this they pass back the customer???
Silly question, nothing of course
Fixes: 480
About the same as they charge BT customers to use this service?
ScottyKernow
Maybe not BT customers, but they are selling access
Fixes: 480
Being a user/provider is voluntary. See  https://www.bt.com/help/broadband/how-do-i-opt-out-of-bt-wi-fi-
Also you get priority if you need all your bandwidth - https://www.bt.com/help/broadband/bt-wi-fi--common-questions-about-sharing-your-connection-with-ot
