PlusNet Hub One - Port Forwarding Issue
gmcgough600
Hi, hoping for some help with an issue I’m having with a new router. The issue is when you go into 'User Defined Games & Applications' to set up port forwarding and create a new one, example given below:
A1D857F8-4C4A-4DAD-BA72-D331E72DBF0E.pngEBD94819-34FB-49F3-A496-146396537180.png3F288368-DF33-4953-A016-BD08B0390504.png
This seems to work but when I try assigning it to a device I get an error. This appears even if I don't have any port forwarding rules set up. Picking one of the pre-defined games/aplications seems to work fine.
thanks!
1 REPLY 1
Re: PlusNet Hub One - Port Forwarding Issue
Hi @gmcgough600
If I recall this issue occurs when a mouse pointer is NOT used when creating and applying the rule (I know it sounds silly!)
I have created the rule on my Hub One with no issues
HTH
