Plus net router making hissing noise?
- My Router
- Plus net router making hissing noise?
Re: Plus net router making hissing noise?
06-08-2018 4:24 PM
Thank you for that and since I have your attention can I bother you with another look at https://community.plus.net/t5/Fibre-Broadband/Disconnects-and-slow-speed/m-p/1559217#M80061
I am still having same problems with disconnects and slow speed.
06-08-2018 4:55 PM
09-08-2018 10:58 PM
09-08-2018 11:29 PM
Just joined PlusNet on Monday and a google search brought me here.
My Hub One is chattering away too. Seems to vary in intensity from a gentle hiss to a series of beeps akin to an old 56k dial up modem. More noticeable when using the internet heavily. When the room is quiet I can clearly hear it sitting approx. 8 ft away.
In my case the noise ceases if I disable 5GHz but starts up as soon as it's enabled again. A reset does not fix the issue.
10-08-2018 7:01 AM
10-08-2018 10:56 AM
Probably right @Tridley68
Sounds like you've got faulty routers, and PlusNet will need to replace them.
They may want the old ones back, so they can identify the faulty serial numbers. Whether they are similar and when they were made, etc.
10-08-2018 12:55 PM - edited 10-08-2018 1:07 PM
Hello @Tridley68, sorry to hear the router is faulty. I have arranged for a new one to be sent for you, which will be with you within 3 to 5 working days. We have raised a ticket here, please could you add any information to the ticket you may have in relation to the questions asked.
@JF53, thanks for getting in touch. We are currently aware that some of our router do make a noise when the 5ghz frequency is in use. I have arranged for a new router to be sent also and it will be with you within 3 to 5 working days.
Please get back to us if you need any further assistance.
10-08-2018 2:05 PM
10-08-2018 2:12 PM
11-08-2018 1:38 PM
11-08-2018 3:52 PM
Hi @dan1239,
We don't need you to return the old router and there'd be no penalty if you were to keep hold of this or dispose of this yourself. However, we can send out a returns bag so that you can post this back to us for recycling. Please let us know if you'd like us to send a returns bag.
13-08-2018 11:13 AM
Thank you
The new one came with a returns bag but i wasn't sure whether i needed to return it
13-08-2018 2:15 PM
No worries. If it's not too much hassle I'd use the returns bag and it'll find its way back to us for further investigation.
Alternatively I'd recommend recycling it in line with the WEEE Legislation.
20-08-2018 9:31 PM
My router is also making this hissing/clicking noise upon data transfer on the 5ghz band. Can you check if my router may be one from this faulty batch? I believe it was originally supplied around Oct 2016. My plusnet username is on my forum account should a replacement be available.
21-08-2018 10:18 AM
Hi @iambigred,
Sorry to hear that you have been having issues. I have processed another router for you, and it will be with you in 3-5 working days.
- My Router
